09-01-2023 07:56
09-01-2023 07:56
I got an Alta HR today, but it still has the original firmware installed. So when I try to pair with bluetooth, it shows up as "atom" (not "alta hr"), which I've selected. But when trying to update the firmware, the device can't be found. Even though it can sync my steps!
I reset/restarted the device HUNDREDS of times. restarted the phone HUNDREDS of times, installed/uninstalled the app, forced-stop the app, logged out/logged in the app, tried from other devices...HUNDREDS of times, it does not work.
It keeps on displaying "fitbit.com/setup" on the device, no matter WHAT I do.
I did ask for help on the help centre but they keep telling me to restart this or uninstall that...did not work.
What else can I try?
Thanks!
09-03-2023 05:44
09-03-2023 05:44
I’m having the same problem!!!! Have you found a solution? Please share if you do. Thanks!
09-05-2023 05:46
09-05-2023 05:46
No unfortunately not 😞
09-05-2023 06:06
09-05-2023 06:06
This is soooo frustrating - and disappointing! 😠
09-07-2023 18:00
09-07-2023 18:00
Same problem with me. I even tried a new Alta hr (I bought 2 at the time). Cannot get a display. Customer service could not help me.
Best Answer09-08-2023 19:47
09-08-2023 19:47
Ditto to all of the comments - I’ve been trying to set up my backup Alta HR for weeks now, exact same thing this whole time. It’s found at “Atom”, is recognized as present by Fitbit app, says firmware update is available, starts the update but stops almost instantly and goes back to saying update available.
on the fitbit itself, the screen continues to tell me to go to Fitbit’s setup page. 🤦:female_sign:
While I’m relieved it’s not just user error, or something wrong on my end, this thread is disturbing. If they are just counting the Fitbit Alta HR too old to fix, would be nice if they just came out and told us.
Best Answer09-23-2023 10:13
09-23-2023 10:13
I agree, they should have just left the hardware support as is. I also have two backups because I liked the Alta HR style and didn't want one of the clunky new versions. But they won't get past the setup screen, even though the functions seem to work - counts steps, tracks 250/hr, etc. It seems when they say hardware update is available, they mean buy a new device. So sad when manufacturers have to "update" things that are working. 😪
