Fitbit Alta not responding
I have my Alta for a couple of years now. last week stopped working. When i have it connected with the charger is ok but when i disconnected stops to respond.I conect it with my computer and start but only for as long as i have it connected. Iidon't have the charger with the botton and i dont know wthat else to do.
Nia
17 REPLIES 17
Hello @Nialef, welcome to the Fitbit Community forums.
Thank you for the information you've provided regarding the Fitbit Alta that is not responding.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
I'm having this same issue with my Alta now. How do I fix it?
Hi @CristinaTr, welcome to the Fitbit Community forums.
Thank you for sharing that you've been having the same inconvenience with the Fitbit Alta not responding.
Keep me posted.
Looks like I’m not the only one experiencing this. I too am only access my Fitbit while plugged in. It will show that it is charged, but shuts off as soon as it is unplugged. I’d appreciate being contacted to solve this please.
My alta is also doing this. It's fine when connected to the charger but as soon as it's off the charger the screen won't turn on. I can get it to sync, change settings, etc but no luck.ive done the reset with the button on the USB side of the charger and still doesn't work.
Hella @DavideFitbit
I have had the same problem and I ended up just putting my Fitbit in a draw and leaving it because I tried so many things to get it working.
it would be great to know if I have missed anything.
Hello,
I don't have any information yet .
Are you sure that you sent something? And if yes were?
Same issue. My Fitbit Alta just stopped charging I cleaned the heads, etc but to no avail. Help
My fitbit is not responding to touch or the flip of the wrist. But works fine plugged to charger. What can I do? Battery is full
I’m having the same problem
I have the same issue. It's fine when connected to the charger but as soon as it's off the charger the screen doesn`t work.
Could you, please, advice?
I have same problem. Please advise!
I am also having this problem!
Hi
I am too experiencing this issue like others is there a fix for this...
Hi David I have the same problem with my Fitbit and the restart doesn’t work what can you suggest Tx karen
Hi David I have the sane problem with my fit bit not working
I am having the same issue. I even purchased another Alta because I've had the original for several years now and the new one has the same problem.  Can you please help me before I return the new one as defective?
