06-23-2019
19:30
20:08
06-23-2019
19:30
20:08
My Alta Hr screen all of a sudden didn’t come on when I tapped the screen, I thought it was dead. When I plugged it in the screen started flashing through all it icons very fast and know won’t stop. I tried rebooting it and nothing happened.
06-23-2019 23:54
06-23-2019 23:54
Hi @Catlisa Oh dear! Try restarting it several times more. If that doesnt help then it sounds like it is dying. How long have you had it?
Helen | Western Australia
06-24-2019 03:18
06-24-2019 03:18
I have had it less than a year now. Now it’s just flashing the Fitbit logo
06-24-2019 04:07
06-24-2019 04:07
I have flagged a moderator to come and help you.
06-24-2019 06:02
06-24-2019 06:02
I am having the exact same issue, but my Alta HR is about 1 1/2 years old. I woke up this morning and it was just flashing icons. I put it on the charger and try to restart it and it keeps flashing. For a while, it just went black and died. Then it came back to life and acted normal for all of two minutes before it started flashing through the icons again. I do wear it every day and it's looking a little sad at this point, but not even lasting two years is a disappointment.
06-24-2019 07:27
06-24-2019 07:27
@Catlisa @luckyJQ9 welcome to our Fitbit Community! Since your Alta HR trackers are still experiencing display issues after you guys restarted them as recommended, let me go ahead and forward your cases to our Support team so they can investigate further and provide a solution.
You will receive an email from them soon.
Thank you for your help @NellyG!
I'll be around if you guys have any questions! ![]()
Best Answer06-24-2019 07:48
06-24-2019 07:48
I’ve had my Alta HR 1.5 yrs. It stopped registering HR last week. This week the screen started flashing icons like crazy. I called the help line (tried restarting, etc..) They were super helpful but the problem didn’t resolve. Eventually admin contacted me and offered me a 25% discount on a new one.
Am not buying another Fitbit even though I loved it. Am on my 3rd wrist band because they kept breaking.I expected my Alta HR to last longer and to be more durable.
06-25-2019 11:35
06-25-2019 11:35
@Juego thank you for participating in our Fitbit Community! I'm sorry to hear about the screen issues that your Alta HR experienced. I'm also sorry to hear that your Fitbit is no longer under warranty.
I totally understand how you feel about this and I appreciate your feedback and comments since this helps us to keep improving.
Best Answer07-15-2019 18:51
07-15-2019 18:51
Was this resolved? Mine just started doing the exact same thing tonight. Started the exact same way as well. I’ve tried restarting it several times. It just keeps flashing the Fitbit logo alternating with the charging battery while on the charger. When off the charger it continuously flashes through all of the settings. The green sensor lights won’t turn off.
07-16-2019 04:11
07-16-2019 04:11
They told me that those were signs that it was dead. It wasn't under warranty but they offered me 20% off a new one. I ended up going with a Samsung Galaxy Active that I got a good deal on through Amazon. It was time to upgrade, and I was not thrilled with the quality of the Fitbit.
06-30-2020 17:21 - edited 06-30-2020 17:21
This happened to my Alta hr.. a few days ago battery started draining faster than before then today when I charge it still counting steps but battery Led won’t stop blinking screen is just blank black
06-14-2021 09:47
06-14-2021 09:47
I am having this exact same issue! Did it get fixed? I have tried resetting but to no avail. Any suggestions please? Would it be possible to forward my issue to the support team please?
06-14-2021 19:22
06-14-2021 19:22
Nope i ended up
buying a new one.
Best Answer09-01-2022 12:20
09-01-2022 12:20
My turn! I'm having the same issues as described above. Last night I noticed my Alta HR was blank, but I had just charged it overnight the night before so knew it was charged. As soon as I tapped the screen, it started flashing very fast between all the icons. I put it on the charger to see if that would reset it or anything and it just flashes between the fitbit icon and the full battery icon. If I take it off the charger, it goes back to constantly flashing very fast to all icons. I've restarted multiple times. Please advise next steps for a replacement.
Best Answer04-24-2023 12:48
04-24-2023 12:48
They don’t last very long - avoid this brand.
