Hi @DTTib if you have some dry rice, put it and your Alta HR into a bowl for at least two days (if possible) to get out the moisture. Once that is done, clean the device, especially the connectors and then charge it. While on the charger, do a restart of the device and see if it springs back to life. Only the original charger from Fitbit has the button on it to do a restart. Let us know what happens.
