The only sound you should hear from your Alta HR is the vibration buzz. As far as I am aware it doesnt have the means to make any other sounds. If it is coming from your tracker then I'd suggest you contact Support (link in my signature ).
Helen | Western Australia
Best AnswerI plugged in my Flex 2 tracker tonight and heard a high pitch very faint whistling/ringing? sound. To make sure it was actually my tracker, I unplugged it and the ringing stopped. Plugged it back in and it started again. Haven’t heard this sound before. It is actually very annoying. Annoying enough that I can’t charge it on my headboard as I usually do.
I have a fitbit versa and I had never heard the sound before. I usually charge my versa on my desk but I had to move it out of my room so I couldn't hear the high pitched sounds because it hurts my ears. It sounds like this really high ringing sound of a sort. I just want to know if I can make it stop so my versa can charge in my room not the living room.
