09-13-2020 05:44
09-13-2020 05:44
How do i reset my Alta HR. I was told to press button on USB device. There is no button. Can I use software and if so where do I get it?
Thanks
09-13-2020 07:25
09-13-2020 07:25
The restart button is on the charging cable, near the USB end.
From How do I restart my Fitbit device?
Ace & Alta series
Your tracker should now work normally. If your tracker still doesn't work after a restart, contact Customer Support.
