01-17-2018
11:42
20:08
01-17-2018
11:42
20:08
I record my running data on www.mapmyrun.com but i'm unsure how to link fitbit with this
07-03-2021 03:04
07-03-2021 03:04
Fit bit is not in the list. Smasunf health, garmin is there
07-25-2021 12:01
07-25-2021 12:01
Where is the improve button??
Best Answer07-26-2021 07:30
07-26-2021 07:30
I am sure there are many satisfied Fitbit owners, but to be honest I am somewhat disappointed. I do think although personally devices like this are aimed to work better on top of the range phones etc. Previously to getting my Fitbit I used. TomTom which I was very happy with, had everything I needed. Sadly it had a shelf life, if TomTom still made them I would have bought a new one.
09-30-2021 17:48
09-30-2021 17:48
Fit bit isn’t showing up in connectable apps
Best Answer11-20-2021 01:47
11-20-2021 01:47
According to me this thread is outdated and none of this is actual. The only way I found today (Oct 2021) is to connect myfitnesspal to mapmyrun and then connect Fitbit with myfitnesspal. Then you will find the workout sync to fitbit. (without the Map of course).
03-19-2022 05:55
03-19-2022 05:55
There's no improve tab online or app on my android (Huawei p30 pro, Google working). Neither does it seem to support Fitbit anymore. Garmin is there though...
04-13-2022 21:44
04-13-2022 21:44
Apps and Devices ->Heart Rate monitor->Connect-> (then it will scan for devices and pick up your fitbit if you're lucky) I didn't get it to connect.
04-04-2023 07:20
04-04-2023 07:20
This does not work. Fitbit does not send the heart rate with bluetooth.
