05-16-2022 10:51
05-16-2022 10:51
Hey guys, I have an altar hr which I have only just started using. I have brought a clip for it as I can not wear any watches at work. Is there a setting to change it from strap to clip?
Thank you
05-16-2022 11:12
05-16-2022 11:12
Hi @xmelkelx the Alta HR can't be used accurately with a clip, so there is no setting as there is on the Inspire 2.
Best Answer05-16-2022 11:25
05-16-2022 11:25
Oh ok, Thank you so much for replying. I will have to look into updating to a newer one I think 😊
Best Answer05-16-2022 11:40
05-16-2022 11:40
@xmelkelx some people have used an extender and worn the Alta or Inspire series on their ankles, too. The Inspire 2 does have the setting and an optional clip.
Best Answer05-16-2022 23:42
05-16-2022 23:42
05-26-2022 05:00
05-26-2022 05:00
@xmelkelx It's true that the Inspire 2 has the On Wrist/On Clip setting. Certain features are turned off when you put in On Clip. Your Alta HR can't track your heart rate in your third party clip. The way I see it, there is no difference between the two devices this way. I don't see a strong reason to upgrade to a new device. The ankle strap is a good idea, too. I've done this with other models. The heart rate seems to work well if you put the heart rate sensor an inch or two above your inside ankle bone.
I hope this helps you get the most from your Fitbit.
Laurie | Maryland
05-26-2022 07:34
05-26-2022 07:34
