02-26-2024 12:26
02-26-2024 12:26
I have not used the Fitbit Alta for a while. My firmware ver. is 21.24.19. The lastest firmware ver. is 21.40.2 but my Fitbit software will not install the latest version. Ant help out there?
03-02-2024 05:26
03-02-2024 05:26
@Rodarick Other users started posting about this issue last summer. I think Fitbit removed the updates from the Alta HR and other older discontinued models.
Laurie | Maryland
Best Answer02-26-2024 12:46
02-26-2024 12:46
Hello @Rodarick
I moved your post from the Fitbit.com platform forum to the Alta product help forum since your issue isn't related to the on-line Fitbit dashboard.
Hopefully, someone here who has experience with the Alta will be able to help you.
02-27-2024 11:32
02-27-2024 11:32
If you find a solution, I am also having this issue. The tracker is still syncing with steps and heart rate but my watch is stuck on the setup notification and the firmware won't update.
03-02-2024 05:26
03-02-2024 05:26
Laurie | Maryland
Best Answer03-23-2024 16:23
03-23-2024 16:23
Did you manage to find a solution?
I am having the same issue.
Best Answer03-26-2024 19:40
03-26-2024 19:40
