03-26-2023 21:31
03-26-2023 21:31
Hi, I bought a Fitbit Alta 3 years ago (2020) from Amazon, not directly from Fitbit. I liked the slimness of it but it wasn't a very durable product. The band broke 3 times in 3 years and it was just from normal wear and tear. Had to buy replacement bands but I can work around this problem.
There's a bigger problem though that I cannot fix. The Alta seems to have battery problems. I recharge it at least once a day, charging it up using the recharger cable that connects to my PC via its USB port. However, the battery doesn't seem to last long anymore, even if the Alta shows the battery power at 90% charged. There's no consistent mark where the Alta goes dead. Sometimes it dies at 90% charged, sometimes at 50% charged, sometimes at 25% charged. Sometimes the battery discharges completely from 50% to 0% and I can't reset it until the battery is recharged.
I suspect the lithium battery in the Alta has degraded and now discharges erratically at times. So I need to buy a replacement. Any recommendations for a newer model of Fitbit that is slim like the Alta, but with better battery reliability?
03-27-2023 03:57
                              03-27-2023 03:57
The two slimmest trackers are the Luxe and the Inspire 3. They have similar features, but differ in their look. The Inspire 3 also advertises up to 10 day battery life.
Laurie | Maryland
03-28-2023 17:31
                              03-28-2023 17:31
If you can swing it, I'd go for the Luxe, but as @LZeeW said, the Inspire line is also a great choice.
one cruise ship at a time! Best Answer
 Best Answer04-07-2023 04:17
04-07-2023 04:17
I’d recommend that if you don’t mind the extra width, a Charge 5 or if you still want slim design the Inspire 2 or 3 or the Luxe, as these are all great trackers.
