08-15-2019
20:38
20:08
08-15-2019
20:38
20:08
Not a request for a new feature but one to give us back a feature that was available before July 28, 2019.
Fitbit no longer gives information on heart rate when using GPS by going to "Excercise" >"Track">"Run", "Walk" or "Hike". In order to get the heartrate status, we're having to use the Excercise Auto Detect feature.
Having the original feature is so muh more helpful. Please let us have it back.
I have an Alta HR.
Since I can't edit my request, I'll have to post again. Sorry.
Auto Detect Excercise doesn't give you mapping, only using GPS does. Currently using GPS doesn't give you heart rate information. I want this on the Fitbit app, that's why I bought a Fitbit with heart rate capabilities in the firt place.
Thanks again..
08-16-2019 12:42 - edited 08-16-2019 12:44
Hi @the3amigos thanks a million for your feedback.
The information that you've shared in your post is really useful. We're currently investigating this issues related to heart rate. Thanks for letting me know that you noticed this behavior when you're using Mobile Run from the Fitbit app. Are you able to see heart rate when you're running or doing any other activity?
By the way, I've sent you a PM with some important information about your posts.
I'll be around.
Best Answer08-17-2019 14:06 - edited 08-17-2019 14:09
Thank you for the inforation on editing a post, very helpful!
I see where my original post was fairly confusing.
I can see my heatrate on the dashboard as it changes throughout my walk but it doesn't record the changes under "weekly excercise" unless I autodetect the walk. Of course if I'm recording the walk using GPS, dashboad is unavailable.
If I use GPS, I get the recorded map but no record of how much time was spent in fat burn, cardio, or peak.
I want the capability back of using GPS and getting my heart rate (fat burn, cardio, peak) recorded for the walk. I want mapping and recorded heat rate stats. We had this feature prior to the end-of-July update.
I hope that was clearer and I apologize again for the badly worded first post.
08-19-2019 08:57
08-19-2019 08:57
I’m having the same issue. Trying to train for a half marathon so I need the GPS run recording mileage but the heart rate data was really useful too and now it’s not there. I get heart rate data for exercise auto detected but then I don’t have the mileage.
08-19-2019 16:48
08-19-2019 16:48
I found if I manually add an exercise after the fact and match start time and duration to my run, a new entry is created with the heart time chart, plus a bar chart with peak, cardio and fat burn times. It just does not get integrated to the tracked event.
weird. Oh, and it computes calories too, but the value differs from the tracked event even if the times are matched perfectly
08-25-2019 20:16
08-25-2019 20:16
It's been over a week since your reply. Is there any news? I'd REALLY like the feature back.
09-08-2019 12:27
09-08-2019 12:27
So, any information? ANY responses? Still unable to track GPS plus heart rate levels during the walk. We had it before, please give it back.
You've admitted it's a known issue, when can we expect it to be resolved?
04-12-2020 21:52
04-12-2020 21:52
Hello @YojanaFitbit ,
Few days ago I found out the same issue reported in this thread happens to me. Since your reply is dated many months ago I wonder if you have some information to share.
Best Answer04-13-2020 04:12
04-13-2020 04:12
I'm wondering if this happens on all phone platforms.
05:59
17:43
JuanFitbit
04-13-2020
05:59
17:43
JuanFitbit
I do. First off, Fitbit is clearly not interested in such matters, so give
up on them forthwith.
Second, there is a functional workaround. Once you complete a tracked
exercise for which you wish to see the heart rate line graph, create also a
manual exercise entry with identical start time and duration. A new
exercise will appear with the line chart. No gps/map or distance segments,
but the heart rate line with be there, along with peak and averages. And, a
calorie burn value that will not agree with the original exercise track.
But, you at lest get the heart rate information.
r.
Omaha, NE
Moderator edit: removed personal information
Best Answer11-05-2020 04:14
11-05-2020 04:14
Why is this STILL an issue.
Previously worked, and then it just stopped.
Over a year and not fixed.
RIDICULOUS.
08-07-2021 17:35 - edited 08-07-2021 17:37
Has it been resolved yet? It's now 2021Q3 and I'm having the same issue. Please fix the issue ASAP
Android System
Samsung S8+
Fitbit Alta HR
08-08-2021 11:37 - edited 08-08-2021 11:55
I doubt very much that this will be resolved to your satisfaction @jc999
