03-11-2016
08:33
21:34
EstuardoFitbit
03-11-2016
08:33
21:34
EstuardoFitbit
Hi everyone,
I just received my Alta after pre-ordering. I am currently in the process of setting it up using the android app. Right now it is not seeing it while my bluetooth is on. The first screen says Power Up, and it is searching for it but does not find it. After that, the Not Working? screen comes up, and you have the option to try again. After selecting try again, It then says Bluetooh Issues. This is where you can restart Bluetooth, which I've done multiple times already. I know my bluetooth works on my phone because I have it setup to work with my headphones with no problems. I have it securely connected to the USB pin connecter which is then connected to my PC. It is charging so I know there is connectivity. I've restarted my phone a few times, but to no avail. I never had any problem connecting with my HR. Has anyone else experienced this with the Alta, does anyone know of anything that I could do to fix this issue.
Thanks!
Moderator edit: edited title for clarity
I'm having the same issue, I've tried everything...resetting, re installing the app etc. This is also a brand new Alta that replaced my 3 month old Alta that stopped syncing with my phone...very frustrating and I really like Fitbit.
Best AnswerAfter an eye watering 3 hours i give up and posting here! I have just received Fitbit Alta and its cable. (I dont have the PC dongle). after trying all options, phone restart, app reinstall, BT restart and Alta restart (3 times press), it just wont connect to Android App and just stuck on 'Not Working?' Message which is useless! hoping to find a fix somewhere..
11-10-2016
14:16
10:51
AnnieFitbit
11-10-2016
14:16
10:51
AnnieFitbit
I'm very disappointed with fitbit's quality. We just received a replacement Alta and it is suffering from the same issue as others on this forum: the app is requesting a code and the Alta is giving us a big, fat "fitbit.com/setup". We tried the restart with the 3 button pushes, to no avail.
Here's our history with Fitbit, my partner and I bought two trackers together 3 years ago. They were both Fitbit Flex models. My partner had her first one go after 6 months, we got a replacement. Mine went after 9 months, we got a replacement. My partner's replacement went after another 6 months, we got a second replacement. My replacement went after 6 months, at which point it was out of warranty so I gave up and bought a Gear Fit and haven't looked back. My partner's replacement's replacement went after 9 months, so it was out of warranty as well. We bought a Charge, since she really loves the challenges with her friends through fitbit and didn't want to go with another brand because of that. That lasted about 9 months and now we have a replacement Alta that I can't even setup. If you do the math, we've had 5 Fitbit Flexes, 1 Charge and now an Alta and none of them have lasted more than 9 months. My Gear Fit is going strong after a year and a half. Fitbit just makes lousy devices imho.
Moderator edit. Format.
Hello everyone! I'm happy to welcome new people to the Community! Thank you very much to @Twin and @Rich_Laue for the great help they have provided! ![]()
For the ones who haven't tried any troubleshooting for their set up or sync issues, I'd recommend following the tips my friend @HelenaFitbit provides in her post for these issues.
If you have tried the troubleshooting steps with no success, I'd recommend contacting our Customer Support team, and they will gladly assist you further with this!
Keep me posted if you have any further questions! ![]()
Was my answer helpful? Awesome! Let's help our fellow Fitbitters by marking this as a solution, and vote up! 😄
Best AnswerThanks for the hint on hitting the reset button 3 times in under 8 seconds, that was enough to make it work for me. Thank you!
Best AnswerI I have been having the same issues as you have said but somehow it registered that all of a sudden everything had gone right and took me to the dashboard. But, when i double tap on the fitbit screen, it shows no date of time.
Welcome to the forums @all_books_glory @P-Simpson! I'm very happy to welcome you to the family. 😄
I'm very glad to see the restart has worked @P-Simpson! That's awesome.
@all_books_glory, in your case, my best recommendation is to restart your tracker as well. You can do it 2-3 times. It has worked for me! To restart your tracker, please plug it to a computer with the charging cable, and press the button of the charging cable 3 times within 8 seconds, waiting 1 second per press. After the last press, wait a few seconds and you will see the Fitbit logo for showing it's restarting.
Also, please keep in mind the best way of tapping your tracker for activating the display.
Let me know if you need anything else! ![]()
Thank you for letting me know @all_books_glory! ![]()
To confirm, is your tracker not syncing to your computer, or it's not turning on when you plug it to your computer?
If it's not syncing, I'd recommend following the tips for syncing troubleshooting, provided by my friend @HelenaFitbit in her post.
Give it a shot and keep me posted with the outcome! ![]()
Best AnswerIt's a lovdely idea but there doesn't seem to be a button on the charge cable, making it impossible to followyour instructions
Best AnswerDid you ever get the issue resolved? I am so frustrated... never had issues with my old tracker. Very dissatisfied and saddened by the poor accessibility to a tracker twice the price.
Best AnswerHave you tried the following ?
1. Remove any Fitbit device that may appear in Settings / Bluetooth
2. Remove device from Account option inside Fitbit app
3. Uninstall Fitbit app; don't worry about your data, they are all in your account
4. Install Fitbit app again
5. Add the Fitbit device again through the setup procedure
it worked for me !
Best Answer@sandromf it was either the romoval of the Fitbit from the phones Bluetooth settings or the uninstalling/ installing of the app.
Removing the tracker from your account only tells Fitbit you do not want to use the tracker. Making it harder to fix a non sync problem, plus any unsynced steps will get thrown away.
Do not remove the tracker from the app.
The app needs to know what tracker is connected to your account to be able to sync.
You wint be able to add the tracker back to your account until the sync problem is fixed.
