08-24-2020 11:57
08-24-2020 11:57
My fitbit has switched to only showing steps per thousand. Ie 10,000 then 11,000 then 12,000 etc. It is not giving me the step count inbetween these numbers. How do I correct it? Thank you
08-24-2020 14:09
08-24-2020 14:09
Hi @Spithead you probably have the orientation of the screen face where it's skinny. If you change it, you'll see all the numbers. I have the Alta HR, too.
08-24-2020 15:11
08-24-2020 15:11
Thank you , that makes sense but how do I change the orientation? TIA
08-24-2020 15:16
08-24-2020 15:16
Thank you again! I have managed to change the orientation. You were absolutely correct.
08-24-2020 15:41
08-24-2020 15:41
It makes a difference seeing all the steps doesn't it? Glad you figured it out @Spithead
08-25-2020 00:27
08-25-2020 00:27
I have been absolutely been pulling my hair our trying to sort this problem. I unpaired device as it just wouldn't sync which fixed that problem but then found I could only get the skinny view. I've now learnt something new, thanks to you, so all's come well. Have a good day. Thank you.
