02-06-2020
15:46
19:45
02-06-2020
15:46
19:45
I see other people are having the same problem, what's the problem?
Hi @Lhcjudy77 not everyone has the identical problem and some people just need to restart their Fitbit or their mobile device. What's your story? The more you share, the better to get you the help you need.
02-07-2020
14:14
08:13
02-07-2020
14:14
08:13
Hello @Lhcjudy77, welcome to the Community Forums!
Thanks for your post, I'm sorry to know that you're experiencing syncing issues. To resolved this, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward to the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes.
@Odyssey13 Your support is appreciated!
Keep me posted, I'll be around if you need anything else.
