04-08-2021 19:36
04-08-2021 19:36
How can I change the time
04-08-2021 20:54
04-08-2021 20:54
Hi @Ellakeep the time on the Alta HR comes from the device you set up to sync with and you can't manually set it. Try syncing a few times and be sure your time zone is correct.
