Hi @SAHMYAA0522 there are none at the online Fitbit store, so you'll need to try other retailers. You can also check with Amazon.
Best Answer@SAHMYAA0522 Amazon still sells bands for the Alta HR. I used these straps when I had an Alta HR. I found them to be more comfortable than the original band that came with the Alta HR.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
Also I humbly suggest AliExpress that has a wide offer of Alta and Alta HR bands. I'm not sure I can post direct links that might violate the guidelines
Best Answer@SunsetRunner Since you asked, here is a link to the Fitbit Community Guidelines. Many of us post direct links to sites with other options. If you are advertising YOUR product, then I can see where this would run afoul of the guidelines.
Laurie | Maryland
@LZeeW Thanks a lot. I asked simply because guidelines are just "guidelines". I got already a post removed for violation of guidelines but, even if I asked clarification to the mod explanation few times, I got not reply when I actually didn't see any violation.
Thanks again.
