01-14-2019
05:58
17:06
LanuzaFitbit
01-14-2019
05:58
17:06
LanuzaFitbit
My Noom app says it will sync data with fitbit but I can't seem to figure it out. Does anybody use Noom and fitbit together and if so, how? Thanks
Moderator Edit: Labels
Best AnswerHi, @KTweds56, Noom is not an officially supported app. However, although users have supported some difficulties in getting them working together, following some updates from Noom, it does seem to be working for some.
You can find some helpful tips and troubleshooting advice by following this thread.
I hope this helps. Please let us know if you get it going, as that may help other users. Welcome to the forums!
Best AnswerHi, @KTweds56 (Karen!) if you have found a work around it would be great if you could post it to help other users.
Glad you have worked something out.
Hi, @KTweds56, thanks for posting!
I am pretty sure your steps disappearing in Noom is an issue for Noom, so it would be a good idea to get in touch with their support team and take this up with them.
Nice to see you visiting the Fitbit Community for the first time @KTweds56! The Noom app is not in the list of the compatible apps listed. If you already tried, like suggested by @Julia_G, to revoke access and the issue still persists, you should follow the advice from @Julia_G and contact the Noom support team. If you have any further questions or need assistance do not hesitate to post again and the Community will try their best to help.
@Julia_G thank you a lot for your help! I gave you kudos. ![]()
Have a sunny day!
Hat dir mein Beitrag geholfen dann markier ihn als Lösung und gib mir Kudos![]()
Hi
I tried to use this workaround, but when I reached the step count page, there were no 3 dots at the top anywhere.
I had trouble too. I just went back and disconnected my Fitbit and then reconnected again. This time I gave permission for everything and the steps synced properly! Good luck!! 😕
How do you put in your Fitbit numbers manually?
Best AnswerI had the same issue but I solved it by installing Power Sync. You have have it sync to your iPhone health app and then Noom. Or have Noom sync right from Power Sync. I like it as it does it automatically (for a fee) or free I’d you want to manually push the button.
https://apps.apple.com/ca/app/power-sync-for-fitbit/id1071544839
01-15-2020
12:52
06:02
JuanJoFitbit
01-15-2020
12:52
06:02
JuanJoFitbit
This worked for me! Thanks! 🙂
EATMS' post about disconnecting fitbit on noom and then reconnecting and "allowing all" worked for me! Thanks so much!
Moderator edit: merged reply
Best AnswerStill struggling with this....Hillat, thanks for clear directions. When I go thru steps & click on Noom, it goes to a blank screen. Did u see a choice for turning those 2 options on?
Best AnswerI have this same problem as well. I did everything on the Noom end, but I know that something needs to be done on the Fitbit end or it won’t sync. When I use my health app on my iPhone it works because I had to go into the health app and fix it so it would sync.. When I looked Fitbit doesn’t support the noom app technically so I’m not sure how people are getting it to sync up.
Best AnswerThank you so much. This is the only thing that has worked for me.
