11-21-2019
06:36
16:21
LizzyFitbit
11-21-2019
06:36
16:21
LizzyFitbit
My Alta HR won't go past the set up screen and won't pair with my Samsung S8 Edge
16:28
14:00
11-21-2019
16:28
14:00
Hi @Wantttobehealth. Welcome to the Forums.
I'm sorry that your Alta HR isn't completing the set up process and thanks for your efforts. Your Samsung Galaxy S8 Edge seems to not be part of our compatible devices list and that might be the reason why it's not completing this process. While we cannot guarantee that it'll pair or always work with all the features, let's try working on this together. Before anything else, may I know if you're getting an error message on the app? Have you made sure to turn on the location services as well to allow the Fitbit app to run on the background?
If you've not done so, please give a try to the following steps:
Best AnswerThe app seems fine....it tries to "find" my alta but cant. The alta sits at the Fitbit.com setup screen.
I will try the suggestions and let you know.
I hope it works...if not I guess healthy is not in my future
12-02-2019
10:10
13:59
12-02-2019
10:10
13:59
Hi @Wantttobehealth. It's great to see you here again. I'm sorry for the delay.
Thanks for sharing more details about your Alta HR's behavior. I know how you feel about this whole situation and please give a try to the steps posted above to get your tracker syncing correctly. If the issues persists, don't hesitate to let me know so I can further investigate and help you out with this.
