06-23-2016
06:39
11:10
06-23-2016
06:39
11:10
It's great to see that you've visited the Fitbit Community @Altawontturnon! I hope you're doing great!
Fully charge your tracker take a look at this article in order to make sure that is charging properly, then perform the restart 2 or 3 times in a row make sure you're following the instructions that @CindyFitbit shared, if the issue persists contact support so they can review your device history and tell you the options.
Hope it helps!
@jelissai It is a pleasure to have you in the Fitbit community with us. Thanks for restarting the Alta and for checking the aligned contacts. If the issue persists, please attempt to clean the contacts with a little piece of cotton and a little bit of alcohol. If you have the same result, I invite you to contact Fitbit support to receive further assistance.
Let the community know how it goes.
