07-05-2018 13:44
07-05-2018 13:44
Since the last update of the fitbit app for Android I have noticed that the fitbit app is using a lot of battery power. I was once able to get over a day of battery life. Now I am in need of charging constantly.
Also I have noticed that the app seem to use a lot of data. 1.17GD of data was used in just under a month. That seems excessive for an app like this.
07-05-2018 14:54
07-05-2018 14:54
I am having the same exact issue. I normally have great battery life, but it is currently draining my second charge of the day and my battery monitor is stating that 20% of the drain is coming from the FitBit app.
Best Answer07-05-2018 16:02
07-05-2018 16:02
Hi there
A lot of people are having this same issue. Fitbit is aware of it. Check this page:
https://community.fitbit.com/t5/Versa/Sudden-phone-battery-drain/m-p/2810867/highlight/true#M32250
- about the 4th post from the bottom
07-05-2018 16:02
Here is the original thread that Fitbit (for some reason) moved to the ionic forum.
https://community.fitbit.com/t5/Ionic/Mobile-data-usage-increased/td-p/2807070
Bottom Line: No fix yet
Bottom Line2: They are supposed to be working on a fix
Bottom Line3: I'm not sure where Fitbit would notify us when this is fixed.
07-07-2018 04:19
07-07-2018 04:19
1) The thread moved back to where it has started:
https://community.fitbit.com/t5/Android-App/Mobile-data-usage-increased/td-p/2813906
2) Fitbit seems to handle this issue serious (at least), with a closed beta test:
