07-06-2017 17:32
07-06-2017 17:32
Hi there,
I'm having some issues with battery life occasionally with syncing. One case where this happens is when the error Tracker Not Found shows up. When this appears, my battery will begin draining around 1% per 2 seconds. If I attempt to reboot my phone at this point, my battery will flatline to 0% and remain on just long enough to tell me it's going to shut off. This can appear after I've recently synced my Charge 2 HR to my phone and typically happens when I'm on LTE, though it has happened at home. When it occurs I can plug in my phone and it simply cannot charge fast enough to keep up with the drain, leading me to believe there's some sort of infinite loop going on.
The second issue is similar, where it will take an awfully long time to sync or may not sync at all. The blue bar at the top of the screen will not progress past roughly 10%, and this is when I have All-Day Sync off so it shouldn't really be trying to sync by itself anyway. At this point the battery will not drain, but when I reboot it will typically drop to 0% or a really low amount. Also worth noting that while this is occurring, the device is slow to respond to commands leading me again to wonder if it's an infinite loop.
The third thing isn't related to this, but is a general question/suggestion. I have All-Day sync turned off because I would rather sync when I'm home and know I can plug in my phone if my battery is going to tank(this has happened on trips), however the option seems to be ignored and whenever I attempt to open the app it attempts to sync. I'm not 100% sure if it's loading data from the phone, which shouldn't really take that long considering it should really just be loading integers and a few doubles. Drawing the sleep graph may take a while but still doesn't seem right that it would take that long.
Another thing I noted regarding the battery, is that when the battery drain occurs, the device keeps attempting to sync but nothing progresses. It will show "syncing" on the specific device menu, then show "last synced: a moment ago", then try again. Bluetooth can be hugely battery intensive and if the app keeps checking over and over again for no real reason(it has already synced in these cases), it's draining the battery for no real good reason.
I this has provided some insight into these issues and that you can fix them. I know my phone is old, but I don't have a really good reason to upgrade and I don't think it's the phone that's the problem in this instance.
Best Answer07-09-2017 09:18
07-09-2017 09:18
Welcome to the Forums @sweatlord!
I'd like to discuss each of the situations you mentioned one by one.
I hope you find this comments useful! Let me know if you have any further questions.
07-09-2017 09:18
Best Answer07-09-2017 19:20
07-09-2017 19:20
Hi @LanuzaFitbit, thanks for the suggestions.
As for #3, I understand why it works that way, but would prefer if it only updated whenever I synced. I can manage. Have a nice last little bit of your weekend!
Best Answer07-10-2017 09:38
07-10-2017 09:38
Hey @sweatlord!
Thanks for the nice words, I hope you have a great week. It's really great to read something like that.
I understand how it can be inconvenient at times, the best way to go about preventing any syncing is to turn off the Bluetooth on your mobile whenever you do not want it to happen at all.
Please let me know if you have any further questions or need any sort of help.
Best Answer09-17-2017 14:20
09-17-2017 14:20
I'm having similar if not the same battery drain issue(s). I tried your suggestions, but no luck. The only thing I've found so far that helps is to delete the app and reinstall. Unfortunately though, the problem typically reappears within a few days.
Best Answer09-18-2017 08:00
09-18-2017 08:00
Hello @75002r66,a very warm welcome to the Community.
That sounds very inconvenient. Have you tried force closing the app instead of only going back to the home menu? It could be that the app is constantly trying to run in the background and that is causing the battery drain. If you close the app, instead of having it on the background, the battery life should improve.
