11-28-2018
11:20
09:36
11-28-2018
11:20
09:36
@Kyfyfe Welcome! Thanks for being part of our Community! Sorry to hear about the issues you are having with your Blaze's battery. What it is happening? Is it not charging? Is it draining quickly? Could you add more information about this issue? Have you tried any troubleshoots?
I look forward to your reply!
What kind of battery issue. if it drain so fast means the battery lifetime seems to be en soon. or if you are using more data consuming apps or mobile data is on for long period so it may cause to a battery issue.
