07-22-2016 10:20
07-22-2016 10:20
I just got a Blaze and an S7 Edge. My Blaze will sync and update my information on the FitBit app, but it will not connect to track my walking or biking via GPS. The location settings are on. I've taken the FitBit app off the phone and reinstalled it. Any suggestions? Buying a new phone or FitBit is not an option since both are brand new.
It seems both have been on the market long enough that they ought to be compatible.
Best Answer07-24-2016 07:17
07-24-2016 07:17
Swipe down on the status bar, do you see that notifacations are running? Do you get call and or Text notifications? Is location services set for high accuracy GPS, cell, and wifi?
07-24-2016 13:35
07-24-2016 13:35
I've had the notifications both "on" and "off." That didn't seem to make any difference. Location has been set for high accuracy, GPS, and Wifi. The Fitbit was still syncing for details, but wouldn't sync with the GPS to record any distance.
After my initial post, I uninstalled the app and reinstalled it again. I found that if I keep the app open and then connect from the exercise menu on my Fitbit, then the phone and the Fitbit will sync and the GPS will *mostly* track my ride. It seems to be dropping once-in-awhile and then the stats for distance are lost, but better than no stats at all.
Thanks for responding.
Do you have any other suggestions?
Best Answer07-25-2016 16:46
07-25-2016 16:46
@revkjc The Samsung Galaxy S7 Edge is currently not listed as a supported device. I recommend keeping an eye on the list as this is where we will be adding it once it's been fully tested by our Android team.
03-23-2017 17:57
03-23-2017 17:57
I also have the same problem with my fitbit charge 2. It does not track my biking exercise. My phone is sony z2. It appears connect with my phone to get gps data for about few seconds then disconnect. As such it does not track my distance for biking. How to solve this problem. Tk
