Hello @Noteedgecharge2, I've saw you were experiencing issues to set up your tracker. In case the issue persists, (Android only) double check the following information:
After you have reviewed the requirements to sync try to do the following:
Keep n mind you can try with your computer, but if you have paired your tracker already using a different device, you don't need to pair the tracker again. Just log in using your Note 4 and your tracker should appear ready to sync.
Hope this helps and let me know how it goes. See you later!
