Keep getting a notification to restart my Bluetooth every few seconds while in the Android Fitbit app. I have uninstalled and reinstalled the app. I have restarted my phone (Galaxy s6) and still getting the message which makes it difficult to navigate the app. With the message popping up repeatedly.
Best Answer@Mroy1980 Hi and Welcome - Have you check the following article that may provide some other suggestions Why won't my Fitbit device sync
also do you have multiple Bluetooth connections that may interfere with this operation?
Is the Fitbit app interfering with other Bluetooth devices
this is directed to pairing with a vehicle but may give an idea or 2
have you checked the OS version of you S6 this may have something to do with it but I am guessing as Fitbit have just changed minimum requirements on most platforms
finally have you tried to un-pair your device then restart phone then re-pair device again
or turn off the Bluetooth to any other devices and just run the Fitbit app to start then add the others gradually
hope something here may help
Kind Regards
Wayne
