07-16-2018 21:10
07-16-2018 21:10
I have tried everything I've found on the chats to get the notifications from my phone to appear on my Charge 2 and none have them worked. The only thing I haven't tried is removing the app and reinstalling it (I'm nervous all my data will be lost). Any other recommendations?
Best Answer07-17-2018 00:35 - edited 07-17-2018 00:36
@Grimomof3 - in addition to @SteveH suggestion
Does your Samsung operate on the Oreo version of the software? (Andriod 😎 if it does have you switched on Fitbit Sync Service notification ? apparently its new to Oreo to make it compatible
you could try to follow my posting in the link below which may help its a bit long winded but I got mine to work (Galaxy S8)
Kind Regards
Wayne
07-17-2018 00:10
07-17-2018 00:10
A common cause of this with the Charge 2 is when it is accidentally put into "do not disturb" mode. This is turned on / off by pressing and holding the button on the Charge 2. Could this be the problem here?
Kind Regards
Wayne
07-17-2018 09:39
07-17-2018 09:39
Best Answer02-02-2019 06:04
02-02-2019 06:04
Thank you! I can't believe I missed that.
