06-21-2017 06:27
06-21-2017 06:27
For a week now Charge 2 has not synced with my android phone. Have tried the following recommended steps;
- Restarting phone
- Restarting Charge 2
- Restarting app
- Uninstalling/reinstalling app (therefore I have the most up to date version I suppose)
- Turning bluetooth off and on again - makes bluetooth go strange, and Charge 2 is apparently non existent according to the phone 😞
Feel pretty worried about this as I've had the band less than two months!
Am I missing anything really obvious?
Thanks in advance.
06-21-2017 08:11
06-21-2017 08:11
I have been having the same issues over the past couple of days. I've tried the same steps as you to get it to sync. It was working fine up until then. I hope it's just a glitch & it gets resolved!!
06-21-2017 15:31
06-21-2017 15:31
I have had mine exactly one month and one day, and am experiencing the exact same problem. I can't believe no one has answered as to what's going on. I'm gonna return it, ugh
Best Answer06-21-2017 18:13
06-21-2017 18:13
I have had mine for 2 months. I love it, but mine has stopped syncing too. I have tried all of the steps they recommend. I really hope they are fixing this!!
Best Answer06-21-2017 18:23
06-21-2017 18:23
You need to supply some basic information like what android phone you're using and software version.
I'm guessing it's not a supported device as there aren't many.
Best Answer06-21-2017 19:16
06-21-2017 19:16
Got the same problem since Monday using Android phone (version 5.1). I had no problem since Xmas.
Hopefully, this will be solved soon ... 😞
Best Answer06-21-2017 19:51
06-21-2017 19:51
Best Answer06-21-2017 20:03
06-21-2017 20:03
Having same issue with charge2. Purchased a month ago, no issues until now
06-22-2017 06:42
06-22-2017 06:42
06-22-2017 09:26
06-22-2017 09:26
Having the same problem since Wednesday. Says can't find tractor. Redid blue tooth, reinstalled app. Checked for updates. Sure hope they do fix this.
Best Answer06-22-2017 14:32
06-22-2017 14:32
I have the same problem withe charge 2
Best Answer08-28-2018 12:32
08-28-2018 12:32
I uninstalled and reinstalled the app and it seems to work. I'll see how it goes for the rest of the week.
Thanks
Best Answer10-21-2018 17:01
10-21-2018 17:01
I have an iPhone 7, and this happens to me every few weeks, for no apparent reason! All of a sudden it says device not syncing because bluetooth is off, when in fact my phone's bluetooth is always on--in fact, under Bluetooth Devices the Charge 2 is clearly listed as being connected. Obviously some sort of bug in the Fitbit. The "cure" is turn the bluetooth OFF, then back ON, and the Fitbit almost immediately admits it is connected and all is well. Until the next time.....
Best Answer10-21-2018 19:15
10-21-2018 19:15
Hi, I had a similar issue, but with other devices. Please take a look at my solution, maybe it can guide you in the right direction. Look at this thread https://community.fitbit.com/t5/Android-App/Huawei-P20-lite-compatibility/td-p/2634123/page/2
Best Answer10-21-2018 20:03
10-21-2018 20:03
Having the same issues - hasn't sync'd since the 11/10/18 😡
