02-13-2019
15:18
05:48
LanuzaFitbit
02-13-2019
15:18
05:48
LanuzaFitbit
My brand new charge 3 won't sync to my Note 3
Best Answer02-14-2019 05:49
02-14-2019 05:49
Welcome to the Forums @Peacefullyfitbi.
Let me help yo figure out what is going on.
In this case I'd recommend that you try to follow the steps listed in this help article. They should definitely help in getting it all to sync correctly with your Note 3.
Let me know if you have any further questions.
Best Answer02-18-2019 17:54
02-18-2019 17:54
This seems to be an ongoing issue. I done all the suggested items several times to no avail.
Best Answer02-19-2019 09:48
02-19-2019 09:48
Hello @Peacefullyfitbi.
Thanks for trying the steps I recommended.
In that case let's try to run the set up as if you had a replacement device. That should help in getting it all to work.
