08-15-2022 07:03
08-15-2022 07:03
I've been doing the same exact run and in the past before the update I lost GPS connection once every 20 runs now it's every single run at roughly 10 minutes into it what can I do to fix this
Best Answer08-17-2022 09:08
08-17-2022 09:08
Are/Have you been using the Charge 4 internal, Phone or Dynamic GPS settings, and which satellite constellations?
I would check your settings as I sometimes find some of my Charge 4 settings would "randomly" change.
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
