My clock will not stay set no matter what I do. I had an Alta hr, everything was fine with it then I woke up and the time was off, I tried everything and it just kept the wrong time so I bought a versa lite and it is doing the same thing. Every time I set the right time zone, it kicks me back to the wrong time zone.
Best Answer@PamilaK Hi and Welcome - not sure if you have already tried the following (you probably have)
note that you need to sync and what's not stated is the change back to Automatic do this after you have synced your device - also have you checked the location is correct (I keep auto location turned off if im not travelling) it may make it more stable to leave it off if your staying in one area
might be worth trying a device reset as well and then re-syncing as a last resort on this line of action
Hope this give another perspective
Kind Regards
Wayne
Best Answer@PamilaK Thank you for getting back to me with your update - I am glad you managed to get it sorted and hope you continue to achieve your goals
good luck and all the best
Kind Regards
Wayne
