01-10-2021 09:27
01-10-2021 09:27
hey dear community
I got a Fitbit Versa 3 for christmas and i installed it, paired it and gave permissions on my Xiaomi Note 8 Pro. It works fine and I am happy with it, except for one issue, which is not a minor one.
When I start my phone and the Fitbit app, everything works well and the phone synchronizes the watch, but after some time (~ some hours) of not using the app and starting it afterwards it is not able to synchronize anymore. Same happens when I close the app by pressing BACK or closing it via the taskmanager, which happens quite often. The app is not able to find the watch, or to sync it.
After restarting the phone everything works fine again.
Is this a common known issue with the fitbit app? Or is it my phone?
thanks in advance for your answers 🙂
Best Answer01-11-2021 01:31
01-11-2021 01:31
its probably a run in background and.ir battery optimization issue.
Check this case it may help but I guess you need to do the battery optimization too.
Something like, [the 3 dots are vertical]
On the phone check battery optimizations [the options may be different in your version]
Hope this helps.
01-11-2021 04:07
01-11-2021 04:07
Thank you for your answer 🙂
I already did that, the app is installed correctly, I checked all the permissions and the battery saving of the app.
But can I assume, that this does not happen to everyone on android? Because I'm thinking about buying a pixel 5, if the error comes from my xiaomi note 8 pro
Best Answer01-11-2021 04:10
01-11-2021 04:10
Good the app is installed correctly but to be sure did you do Bluetooth as well?
01-11-2021 15:51
01-11-2021 15:51
I'm having the exact same issue with my Samsung galaxy note20 ultra and my charge 2.
Best Answer01-13-2021 09:33
01-13-2021 09:33
If you close the app with the task manager, you only closed half of the app. You will need to do a phone restart, or through the phone settings stop the app.
Your app needs to be running for a sync to occur.
You want the Fitbit app running in the background when the phones screen shuts off.
