05-12-2018 10:53
05-12-2018 10:53
Since this morning the fitbit app is draining my phone battery. It uses up to 400 mAh. Didnt change any settings... and before it never did this. When i restart my phone it is fixed for a few houres but then it starts draining the battery again...
And now?
Fitbit, this week, every time you try to fix something, you guys break something else. And every started with a lousy update for the ionic.
I used to be a very satisfied customer, but lately
05-14-2018 11:12
05-14-2018 11:12
Exact same thing for me. 115 amh used on this app alone! Having to charge my phone twice a day now.
Best Answer05-14-2018 11:29
05-14-2018 11:29
Best Answer07-06-2018 00:30
07-06-2018 00:30
Same here! uses up 20% of my phone battery (447mAh). It did not do this before though - i dont know what happened?
Best Answer07-06-2018 07:24
07-06-2018 07:24
Heb hetzelfde probleem telefoon loopt leeg door de fibit app niets aan instellingen veranderd
Best Answer07-06-2018 07:26
07-06-2018 07:26
I have alsof a battery drain never change settings
Best Answer09-07-2018 05:58
09-07-2018 05:58
Since using fit bit charger HR I need to charge my phone twice a day
