03-11-2016
17:11
05:44
AlejandraFitbit
03-11-2016
17:11
05:44
AlejandraFitbit
Using both apps on a Samsung Galaxy S5 - When I use my FitBit exercise tracker (to log my walks/jogs using the GPS feature) it doesn't want to work simultaniously with my iHeartRadio app.
One or both of them freeze after a few minutes and then start back up on thier own after another 5-10 minutes (FitBit stops counting steps; iHeartRadio stops playing).
This happen for anyone else? Any ideas?
Moderator Edit: format
Welcome to the Community @SunsetRunner. I would like to know if you keep having problems with your iHeartRadio while using the Fitbit app? If you do, keep in mind that this is normal, while using the Fitbit app you won't be able to use any other app that uses bluetooth or GPS signal to work.
Let me know if you have further questions. ![]()
