08-09-2017
16:36
08:23
MarlenS
08-09-2017
16:36
08:23
MarlenS
I've turned on the mobilerun on my android device everyday for the last week. I hit pause and then finish when im done. It logged ns kept Monday's workout but did not keep Tuesday or Wednesday when I did over 20 minutes each day. Why would it store some days and not others? I have tried restarting phone. Only believe this to be an app issue, not fit bit charge issue. Thanks.
Best Answer08-10-2017 08:20 - edited 08-10-2017 08:25
Hello @Photofrenzymom, it's always a pleasure to welcome new Community members. ![]()
I've moved this post from Charge HR to the Android board since I noticed in your Community profile that you own this type of mobile device and this inconvenience, as you mentioned, is related to the Fitbit application nor the Charge itself. Are you missing these activities only from the Fitbit app or also from the online Dashboard? In the meantime, my suggestion is checking first in the mobile device you're using is compatible with the Fitbit application, then uninstall the app, restart your phone and reinstall it back.
Give it a try and let me know the outcome!
What's for breakfast?Check others recipes and share yours!
Best Answer08-11-2017 15:53
08-11-2017 15:53
