04-26-2018
08:50
07:36
RobertoME
04-26-2018
08:50
07:36
RobertoME
After coming back to sweden after a week in New_York, my Flex2 does not sync with my Huawei P20 lite. Help anyone?
Moderator Edit: Updated Subject For Clarity.
Best Answer04-28-2018 07:35
04-28-2018 07:35
Hi there @AnnDav, good to see you have joined the Fitbit Community! I saw you tracker is not syncing with your phone.
Note the Huawei P20 Lite is not listed as a Compatible Device. Nonetheless, this doesn't mean your tracker or the app are not going to work; so I recommend to give it a try to these suggestions: Having trouble syncing? (here's how to fix this)
Hope this helps and stay tuned if you have other questions.
