Hi @didgygirl it is a pleasure to have you in the Fitbit community with us.
Unfortunately, the Honor 5c is not compatible with the Fitbit app. In this case, I recommend you to create a suggestion in order to get this device compatible.
Hope this helps!
Hello @archimax it is a pleasure to have you with us in the community.
Fitbit is constantly working in order to have more devices available for syncing. I would not be able to tell you when exactly is going to be able. I would recommend you to check frequently this link since it's modified periodically.
Thanks for your patience and understanding.
Any update on the Flex 2 / Honor 5C.
My original 2.5 year old Flex syncs fine but the Flex 2 won't sync.
I like the Fitbit dashboard functionality, but if the Flex 2 won't work, it will be going back and you will have lost a customer!
