When logging food I am unable to enter the correct units as the unit menu does not stay active. After entering a numerical amount and clicking on Next, the units menu briefly appears but does not remain active long enough to select the proper unit of measure.
How you doing @SunsetRunner? Thanks for joining this family, hope you like what find here!
Can you please provide more details about it? For example a screenshot, you can check this post to know how to add an image to your post.
In the meantime:
You can also try the solution below :
I look forward to your reply. If you have any questions or concerns please don't hesitate in contacting us.
Best AnswerForgive the necro, but I'm currently having this issue. I've tried the solution you provided but I still have the issue. Below is a screenshot of the screen that has the issue. It is present on most but not all foods. The units menu appears at the down arrow next to the serving size value. It would be helpful if the unit itself was displayed.
Best AnswerI tried to post a screen shot but it didn't work. The instructions in your link are 3 years old. I'll try again.
