06-02-2016 05:02
06-02-2016 05:02
Best Answer06-04-2016 02:22
06-04-2016 02:22
Hi @Alykbb
Have moved this thread from the Charge HR to the Android App section to increase the chance of getting a solution.
Your post will get more attention here.
Best Answer06-04-2016 10:24
06-04-2016 10:24
It's nice to see you around the Community
! First of all, I'd recommend making sure that your Android app is running the latest version (see the steps for updating it in this discussion I had).
Once you've checked that, do the following:
Catch you later!
Best Answer06-06-2016 19:51
06-06-2016 19:51
Hi @Alykbb
I think you might be experiencing the same issue I've documented here, with the addition of a "duplicate" activity from having your tracker auto-tracking (which I've disabled so my walk to & from work don't get counted).
It's being looked at, but I'd advise against logging out of the app on your phone for the time being as this seems to just delete the activity with the GPS data rather than actually fixing anything.
