It sounds like you might have accidentally gotten into 'do not disturb' mode, blocking all notifications. The procedure depends on which model Fitbit you are using.
@Tbebe wrote:
I have charge 2
Sent from my iPad
Okay, good, in the sense that is a common issue with Charge 2 with an easy fix.
There are uses for the side button with a quick press, but if you hold it in longer, for a few seconds, it toggles you in and out of 'do not disturb' mode, stopping all notifications.
