07-05-2022 12:36
07-05-2022 12:36
My Charge 3 stopped syncing when I was in France and since I've come back to the UK it just won't connect to my Bluetooth. I've tried all the troubleshooting - endless phone and Fitbit restarts, disconnecting everything that's already connected to Bluetooth, clearing the Bluetooth cache and storage and using my old phone to try and connect my Fitbit to Bluetooth but nothing has worked. Any ideas?
Best Answer07-05-2022 14:17
07-05-2022 14:17
Are you tryig to pair using your phone's bluetooth settings, or from within the fitbit mobile application? You can only connect using the fitbit mobile app.
https://help.fitbit.com/articles/en_US/Help_article/1873.htm
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
07-05-2022 14:31
07-05-2022 14:31
Hi there
I'm using the Fitbit app. It just suddenly stopped syncing and I've tried all the usual tricks and troubleshooting tips to try and fix the issue.
Best Answer07-05-2022 19:53
07-05-2022 19:53
Hi @Cwallac28 - did you try removing the Bluetooth entry from the phone, then run "+ Set up a Device" and replace your tracker.
Thus should make a new pair in your phone's Bluetooth and enable syncing.
If this doesn't work in the Fitbit App click profile photo, Help & support, Contact Customer support to chat with them.
