12-19-2018
11:00
05:50
LanuzaFitbit
12-19-2018
11:00
05:50
LanuzaFitbit
HELP!! I am not receiving my notifications for my phone calls on my Versa. I have the Samsung Galaxy S7 Edge. I have no problem receiving text, email, or calendar notifications just not getting call notifications. I done a factory reset. I have uninstalled the app and reinstalled. I have turned off bluetooth. Basically I have done everything. I even returned my first Versa and got another one and still the same issues. It is so frustrating!!
Best Answer12-26-2018 14:15
12-26-2018 14:15
I had the same problem with a Samsung S7. No phone calls on watch but still received text and emails. I also tried all the different suggestions and spoke with tech support just to try everything again to no avail. Oddly, I noticed the time on my phone was off by 2 minutes compared to watch and all other devices. Went to phone settings to change the time and found the automatic date and time was turned off. Turned the setting on and thought nothing of it until I recieved a phone call 1 minute later and it showed up on my watch! Has worked flawless since....... Hope this helps.
12-20-2018 05:52
12-20-2018 05:52
Welcome to the Forums @Sheath.
Thanks for letting us know of all of the steps that you have tried in order to get the call notifications to work appropriately.
The first thing I'd like to recommend is that you try following all of the steps listed in this help article. While I'm sure that you have already tried some of the steps, please try going through all of them in the order that they show up. That should definitely help to make sure that everything works correctly.
Let me know if there is anything else that I can help you with.
Best Answer12-20-2018 08:28
12-20-2018 08:28
Best Answer12-21-2018 08:26
12-21-2018 08:26
Hello @Sheath.
Thanks for trying the steps from the help article.
I'd like to ask you some questions about this situation:
Look forward to your reply.
Best Answer12-24-2018 19:31
12-24-2018 19:31
12-26-2018 14:15
12-27-2018 11:15
12-27-2018 11:15
12-27-2018 11:43
12-27-2018 11:43
12-27-2018 12:11
12-27-2018 12:11
I hope they see this also because I am sure there are others having the same issue. This is such a simple fix instead of having to go through all the other steps over and over again.
01-04-2019 09:28 - edited 01-04-2019 09:28
Hello @Sheath and @Versa-tility.
I apologize for the delay in my response.
@Versa-tility Thanks for sharing those steps with everyone! I'm sure that they will be very helpful to others.
If you have the time, maybe you could visit one of our Discussion boards. Lots of different topics to talk about, maybe that will interest you.
Let me know if you have any further questions.
Best Answer01-29-2019 05:42
01-29-2019 05:42
I can't believe that is all it took to fix my issue. I actually spent forever on the phone with Fitbit support and they couldn't figure it out. They actually had me return mine to the store and get a new one because they thought something was wrong with my tracker. I saw that there were many issues with the Galaxy S7 specifically having this problem so I was hoping a lot of trackers would be purchased for Christmas and the issue would become more of a priority. The only thing that worries me is I was having trouble with my time because half of the day it would be correct and the other half of the day it would be an hour off. That is the reason I turned off the automatic time update in the first place so fingers crossed this afternoon the time is still correct. Thanks again for sharing this fix!!
01-29-2019 09:39
01-29-2019 09:39
01-29-2019 10:25
01-29-2019 10:25
01-31-2019 10:29
01-31-2019 10:29
Welcome to the Forums @HappyCamper2. Hello @Versa-tility and @Sheath.
Thanks for taking the time to share your experience and letting us know that everything seems to be working correctly.
If you have the time, maybe you could visit one of our Discussion boards. Maybe you will find a topic that piques your interest.
Let me know if there are any further questions.
