07-06-2018 22:53
07-06-2018 22:53
I'm using the Samsung Galaxy S8 with a Fitbit Versa.
I keep getting errors from Device Maintenance stating the Fitbit App is overloading CPU and must be closed.
My battery is also getting drained like hell but I suppose that comes with overloading the CPU.
07-06-2018 23:49
07-06-2018 23:49
This is the announcement in red at the top of the Android forums fro Fitbit.
"We’re currently experiencing an issue which can cause the Fitbit app for Android to consume a large amount of mobile data, and/or increased battery drain on mobile devices. Engineers are working to resolve this issue as quickly as possible. Read more. "
Welcome to the forums!
07-08-2018 22:58
07-08-2018 22:58
Hi, I have the same issue - using Fitbit Ionic with Samsung Galaxy Note S8.. Need to shut down the app several times a day.. Hope that this issue will be fixed asap..
07-09-2018 02:40
07-09-2018 02:40
Me too.
Samsung S7 Edge. Android 9. Fitibit 2.73.
Phone down by 71% battey in just 2.5 hours.
I am going to have to delete this app. It is killing my phone and making it unviable for a day at work.
07-09-2018 06:23
07-09-2018 06:23
I have a Oneplus 5T but i have the same Issue.
down 55% in 5 hours. Phone is running very hot.
Have a colleague with the same issue(Google Pixel 2).
07-09-2018 07:45 - edited 07-09-2018 07:48
Same here. Have to keep uninstalling and reinstalling the app. Phone running very hot, battery dropping as I watch it. This is taking a ridiculous amount of time to fix now. I'm sure someone at Fitbit must know what they changed between the last two versions. Or is the guy that did it on holiday and they're waiting for him to get back to work? Just re-release the previous version with a different build number and let us "update" to that. I'm sure it'll be fine until they release a genuine fix. We've paid a lot of money for these devices and to not be able to use them fully because of a broken phone app is crazy.
Out of interest, how long do we have until the data on the watch is overwritten? How often do we HAVE to sync?
07-09-2018 08:19
07-09-2018 08:19
This is from the Fitbit support article:
"How often should I sync my tracker or watch?
We recommend that you sync your tracker or watch daily. Most Fitbit devices record detailed minute-by-minute data for seven days. (Fitbit Alta records minute-by-minute data for five days). Fitbit devices can store daily totals for up to 30 days.
If you have a Fitbit Surge, your device can store 35 hours of GPS data before deleting some data to make room for more."
07-10-2018 00:03
07-10-2018 00:03
Hi. I too am struggling to keep my Samsung S8 alive during my working day. Getting the same Device Management warning about the Fitbit App overloading the CPU. The amount if heat being generated by the device is serious! I've had to remove it from it's case, which isn't ideal, and as the battery is also being depleted at an alarming rate, charging send the temperature of my phone sky high. Fitbit, you need to get this fixed before one explodes!
07-10-2018 06:46
07-10-2018 06:46
Hi @TonyBest
Please check out the first post in this thread, updated yesterday about the problem. click to read
07-10-2018 11:22
07-10-2018 11:22
So should have checked this forum sooner. Been sucking the life out of the phone.
56% today was fitbit and I put it on standby.
However, I've uninstalled and now installed the new version.
Fingers crossed.
07-10-2018 12:25
07-10-2018 12:25
I am having the same problem. Fitbit iconic.
07-10-2018 14:01
07-10-2018 14:01
Mine started on Saturday. My phone runs hot, the battery drains in 3 hours and I get the same message popping up.
I just bought my Fitbit Versa 3 weeks ago. No issues until this past week.
Fitbit...please fix ASAP!!
Normally a very happy customer!
07-10-2018 14:35
07-10-2018 14:35
Check out the update at the top of this post! I updated and my battery is already cool.
07-10-2018 14:36
07-10-2018 14:36
Check out the update at the top of this post. My battery is already cool.
07-10-2018 14:36
07-10-2018 14:36
I updated as well and it's made a huge difference already.
07-10-2018 14:37
07-10-2018 14:37
There's an update!
07-10-2018 14:44
07-10-2018 14:44
07-10-2018 15:16
07-10-2018 15:16
07-10-2018 16:17
07-10-2018 16:17
My Note 8 has been doing the same CPU error message for about a week. Draining the battery even when its charging all day. I just updated the Fitbit app so I really I hope this fixes the issue. If not, I'm gonna be livid. Lol
07-10-2018 17:14
07-10-2018 17:14
