Best AnswerHello @Tripsin03 and welcome to the Community! Congratulations on your Alta.
I checked over the compatible's list and the S7 Edge is there, as you can see:
So you do not have to worry for compatibility. Regarding your device if the set-up was completed the syncing should go smoothly. Is your device on Android 6 Marshmallow? If that is the case you will need to turn the location for the syncing to work properly.
Otherwise there is a couple of steps to check out so that you can look into the syncing issue. One of them being a restart of the Alta (thank you @wandamarie).
Please let me know if your Alta syncs properly after this. See you around!
