10-13-2017
21:50
06:09
RobertoME
10-13-2017
21:50
06:09
RobertoME
I have a new surge and it won't pair with my pixel xl. I've tried everything that I can think. Any advice will be greatly appreciated
Thanks
Moderator Edit: Updated Subject For Clarity.
Best Answer10-16-2017 06:08
10-16-2017 06:08
Hello @Vinnie27, nice to see you have joined the Fitbit Community. I'm wondering what troubleshooting steps have your tried? This is just to not recommend possible steps that you might have attempt on your own. Also I would like know which version of OS are you running on your mobile?
In the meantime I'll go with the basic when these situations happen:
See you later and hope this helps.
Best Answer10-23-2017 01:15
10-23-2017 01:15
Thanks RobertoFitbit
It still didn't pair. I got in touch with Fitbit and they said that you are unable to pair the surge with the pixel xl at the moment.
If I knew this before purchasing, I would have got one that you could pair.
Thank you for your help and hopefully they may pair them up soon 😊
Take care
Best Answer11-13-2017 09:38
11-13-2017 09:38
Hi there @Vinnie27, my apologies for my absent after your post. I was checking and our list of compatible devices and the Pixel and the Pixel XL is compatible. So I'm, wondering if you were experiencing any issue in specific?
Perhaps was a misunderstanding with the new models, Pixel 2 and Pixel 2 XL . This devices indeed are not listed as compatible yet and we cannot guarantee its behavior with the Fitbit app and the Fitbit tracker.
Let me know how it goes. See you later!
