Swimming speed
I have a problem with the swimming speed. I swim 2000m in 1hour without a break. The android app says 1'40"/100m. When i login using Chrome it says 3'00"/100m. The last one is correct. Can someone tell me how I can the Android app work correctly? I first thought it is a setting that i missed, but the fact that the chrome login gives a different (correct) calculation makes me wonder if the app is buggy?
9 REPLIES 9
 Hello, @Another_user! Welcome to the Forums! Man Tongue Please try to forcequit the App, log out and back in. You can also try to reboot your phone.
Also, when you say do it from Chrome, are you doing this using your phone or a computer? Please provide me more details of this. And finally please attach some screenshots of both logs at the same time for the same exercise using Chrome and the App.
I'll be around. Man Wink
Solange | Community Moderator, Fitbit
I use chrome and internet exporer from a windows 10 notebook.
Log off and log in again did not work with my Phone, in the tracked exercises it stil shows the wrong pace.
And when i fill in a new swim exercise it stil goes wrong, I do however notice when i type 2000 m it goes wrong with the last zero. This is easy to see because the android app let you see the calculation result change with every digit you type. At 200 it shows 30'00''/100m, and 2000 gives 1"40"/100m
instead of 3'00"/100m.
The android app somehow can't grasp the idea of continous swimming.
I checked it by using different distances, with the forth digit it always goes wrong.
Sorry, I just noted Chrome is on the phone.Smiley Embarassed
Internet explorer and firefox op the notebook.
It may be clear, only the android app gives the strange results
And now the screenshots. First the screenshot from the android app Second a photo from the notebook screen showing dashboard (in internet explorer).
Glad to see you here @Another_user! Thank you very much for sharing those screen shots. It is interesting that the app is not showing the exact same information.
Let's try to uninstall the app from your Android device and then installing it again. It is possible that some component was not properly installed and thus it is not calculating the pace correctly with the information it got from our servers.
Please keep me posted on how the reinstall goes!
Lanuza | Community Moderator
Remember to vote for posts that helped you out! Tired of the same workout music? Try a Podcast! 🙂
I did uninstall the app twice. Once by using the uninstall button in the android playstore. And once by manually removing the app. But when I download and reinstall the app there is no improvement. The calculation goes wrong when I add the fourth digit (from 200 to 2000). See previous post.
Hey, @Another_user! Thanks for the updates! Since you are still experiecing this issue. Please get in contact with our Customer Support team, and report this situation with them, they will be able to further investigate with their internal tools.
Keep us posted! Man Tongue
Hi:
Hi; I have the exact same problem. I emailed the help desk and they said they'd work on it. I told them I couldn't swim 1:40/100 yds without a motor!!
Jeibach
Hey, @jeibach! It is nice to see you around. Thank you so much for the updates about what our Support team said and for your patience. Heart
