02-08-2021
17:56
17:40
RicardoFitbit
02-08-2021
17:56
17:40
RicardoFitbit
Is there a new syncing issue? It was working fine yesterday. Why does this keep happening?
02-09-2021 05:31
02-09-2021 05:31
Hi there @Redhead357, welcome on to the Community Forums.
The issue with the Fitbit App version 3.37 should be solved updating to version 3.37.1. If you continue to have syncing difficulties, please see Why won't my Fitbit device sync?
Hope that helps!
Best Answer02-09-2021 12:51
02-09-2021 12:51
My is at 3.37.1 and still just sits there spinning saying I know it's taking longer than usual. I have reset my phone, re-installed app, this is so frustrating for it was working fine then just quit. Please help!!
02-09-2021 15:37
02-09-2021 15:37
Hi Marre,
Actually my fitbit app stopped syncing after it got updated to 3.37.1
(Versa, Android 10.1.0)
Nothing helps, restarting, reinstalling, etc, etc. Now you even can't add/pair the watch. Time is 15minutes back on the watch already, so it's basically useless 😞
Are they planning to resolve it? When to expect? Any updates? All I can see in other threads is "we already fixed it", while it's not the case
Thanks,
Henry
02-09-2021 17:50
02-09-2021 17:50
I agree this is definitely not the case on the 3.37.1, it's very frustrating not knowing what you did exercise wise for the day. I actually thought it was my phone for I have not experienced this issue before. Hoping this gets resolved soon.
02-09-2021 21:06
02-09-2021 21:06
I wish there was an option to add a screenshot for I tried again by restarting my phone, uninstalling and reinstalling app, turning off bluetooth and back on. It does the same exact thing, once I pair it and add 4 digit code it just sits there saying sorry this is taking longer than expected but we are on it. This time I couldn't get out of it without resetting my phone. Please please get this issue resolved.
Best Answer02-09-2021 22:24
02-09-2021 22:24
And it's definitely the app not the watch. I've deleted the scales from the app and can't add them back too.
Mega annoying, basically I can't use the watch now because of the time lag, as I've reset them so many times trying 😫😖🤬
02-10-2021 06:09
02-10-2021 06:09
Another thing I've noticed is before when I would receive messages they would show up on my fitbit but not anymore. How long does it take for someone to reply to us? I wish companies would make sure an update works before issuing it. Happens all the time with anything.
02-10-2021 06:11
02-10-2021 06:11
I have done everything you mention, please please help!!
02-10-2021 15:51
02-10-2021 15:51
Same, just generic links and no solution so far. Apparently the syncing issue has been going for weeks (based on google reviews and comments here). There was a post asking for some reaction or anything from the company, but they've deleted it saying it was "nonproductive". More appalled by them handling the situation rather than technical issue as such.
I'm desperate, officially back with my regular watch.
02-10-2021 15:59
02-10-2021 15:59
I totally agree with you! I've not had data syncing correctly for well over a week now which renders this useless.. Fitbit has not corrected the issue and keeps throwing us under the bus telling us to search the forum's, reinstall the app, etc and none of this works!
02-10-2021 17:01
02-10-2021 17:01
That's incredible what happened to good reliable customer service that needs shown in order for people to buy!!
02-10-2021
17:02
03:11
02-10-2021
17:02
03:11
agree and I would have liked to hear from forum moderator. This is beyond frustrating.
Moderator Edit: Formatting
02-11-2021 07:13
02-11-2021 07:13
Hello, if you read comments this issue isn't resolved and we have all done everything you suggested. Please please help get this resolved for we are beyond frustrated.
02-11-2021 07:16
02-11-2021 07:16
I have the charge 3 and now isn't working since updated to 3.37.1 please help so frustrating.
Best Answer02-13-2021 03:15
02-13-2021 03:15
Hi everyone! We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services. Thanks for your time and efforts in troubleshooting this issue.
In addition to the steps you've tried, please follow the steps below:
If you can't get started with your Fitbit device, usually a missing requirement is the cause. Carefully review the requirements provided in this help article Why can't I set up my Fitbit device?
Best Answer02-14-2021 15:44
02-14-2021 15:44
Hi Maria,
As mentioned, I've tried everything including steps above of course. Actually tried it so many times that the watch is more than 20 minutes back now, thus useless. I consider myself tech savvy person, so these suggestions to try same over and over again... Nothing but annoyance and further frustration.
Once again, nothing helps after the latest update, it won't sync and can't be added/set up back after removing the device.
There's one viable solution they suggest, downloading some of the previous versions of the application, but I don't feel like downloading a_p_k file from a third party source, security wise, as I use[d to use] watch for payments in particular.
Hopefully some day I could use my watch again, but now it's been useless for more than a week. And it's not just me. Nothing but desperation. You're not just losing customers, you're getting an army of those who would discourage anyone from even considering buying Fitbit first place.
Thanks,
Henry
02-14-2021 18:58
02-14-2021 18:58
Finally.... it's been since January 20th, I was able to fix the syncing issue. App was not pairing with Versa 2, phone couldn't find it, tried all the recommended fixes, and nothing... update would just spin and spin. And watch was losing time. Go to settings on watch and do a factory reset. Follow prompts on screen. Force stop app on settings on phone. Log back in to app. Took an hour. Clears all info on watch, but app will save all your stats from last sync, update.
02-14-2021 19:06
02-14-2021 19:06
Thanks for the info but I have a charge 3 & I've already done everything you mentioned previously and mine still isn't working.
02-14-2021 19:24
02-14-2021 19:24
I've tried over and over everything she suggested and I'm still no further ahead just more frustrated. The upgrade only seems to be affecting certain models, I have the charge 3 and it's been a great unit till the upgrade.
