03-13-2018
14:18
08:12
RobertoME
03-13-2018
14:18
08:12
RobertoME
Fitbit Flex 2 has stopped syncing and recording steps on my Samsung Galaxy s4 mini. Have switched phone off/on again, tried plugging in the fitbit and pressing the button on the fitbit 3 times, all to no avail. The lights appear to be working as normal so don't know what could be wrong. Blue tooth is switched on and fitbit is paired. Anybody help?
Moderator Edit: Updated Subject For Clarity.
Best Answer03-15-2018 08:11
03-15-2018 08:11
Hi there @smithy59, nice to see you are visiting the Fitbit Community! I was reading you are experiencing troubles to sync your Flex 2 despite your efforts to address this issue. I would recommend to review the version of Fitbit app for Android you have installed.
In the last week was released a new version that might help you to address the syncing troubles. Please review your Google play store if there is a new available for you. For more details please review this post.
If you need additional help for syncing issues, check the following suggestions: Having trouble syncing? (here's how to fix this).
See you later and hope this helps.
Best Answer03-15-2018 11:48
03-15-2018 11:48
