08-18-2017 15:06
08-18-2017 15:06
Hey, I'm having an issue with the water consumption on my Dashboard. It adds entries ok for the current day, but when I track back to the previous day's Dashboard or any other prior days, they all show my water consumption as whatever the current day's is. For example today I had 1litre - yesterday and every day before that are showing as 1 litre in the Dashboard when they should be higher or lower for those days. When I actually click into the water section on any day, it shows the correct amount for that day. Anyone know why prior day Dashboards are doing this? The steps etc seem to show correctly for each day, it's just water. Thanks in advance.
08-18-2017 18:36
08-18-2017 18:36
When going back and forward via the side arrows on the dashboard, only the data items on top above the solid line (steps, floors, miles, calories, active minutes) change. To see history of items with tile below the line, have to click on the tile, then should be able to scroll down and see the history for that item. That's just the way it is designed.
08-18-2017 18:36
08-18-2017 18:36
08-19-2017 08:03
08-19-2017 08:03
Ah I see, thank you very much. Kind of annoying but at least it's not faulty! Thanks for clarifying.
