hi just downloaded Fitbit app with no Fitbit accessories just using phone wanted to track steps... it says when you select no device to connect it should be instructions for mobile tracker but I never got them and cant pull it up to setup ( followed all instructions for setup still no luck) need help
Hi, @Note8Guy! Based on your name, I'm going to assume you're using a Galaxy Note 8. If you check the supported devices page, you will see that MobileTrack is not supported on your device. Unfortunately, you'll have to add activity manually if you'd like to try out the features, or use the GPS function on your phone to track specific activity.
MakMak | Community Council
