Fitbit Update 04/26/2016: Everyone -- As this issue seems to be resolved, I will be locking this thread from further discussion.
If this issue pops up again please try the troubleshooting step of unpairing your Charge/Charge HR from your account and then setting it up again. If that doesn't work, please create a new post for the new instance and reference this thread.
Again, thank you to everyone who reported this issue and helped get this resolved!
Fitbit Update 04/15/2016: It's been brought to my attention that Charge/Charge HR users on the Android app, version 2.22 are unable to edit their "Clock Display" setting from the app as the setting is not available.
I'm currently working with our Product Specialist Team who is looking into this. When I get an update on this, I will make sure to share it with you all here first.
As a workaround for now, please edit your "Clock Display" setting from the online Dashboard's "Device Settings" page.
Again, thanks for reporting this! Hope to have an update for you all soon.
Hi,
I've set up my FitBit Charge to my LG G2 phone. Everything seems to be working fine but I'm missing clock face options and call notification in account/settings.
I'm not up on everything that is supposed to be in the app but it seems a little meager with not much to actually change in settings except for goals and a few things under location and advanced. It's like I have a "lite" version of the app.
I've restarted my phone and it didn't make any difference. My phone and tracker are communicating fine.
Its towards the bottom of the setting page. Your not seeing this?
Wendy | CA | Moto G6 Android
On the app if you click on the device name then scroll down I see Clock display there.
If not there then shut down phone. Then go back in. If still not there then you might have to re-install the app
Best AnswerI just upgraded phones and was very confused about this as well. I always set mine to the clock and date display, but the option is completely missing from the latest version of the app that installed on my phone. I really hope someone fixes this.
06:14
06:22
04-14-2016
06:14
06:22
Welcome to the Community @MizCollie. Please confirm you are doing the following to see the clock faces?
1. Tap Settings
2. Tap Tap Devices
3. Tap Charge
4. Slide down to Clock Display
5. Select your clock face
6. Sync
About the calls, I recommend trying the Calls Notifications troubleshoot.
I hope this helps, let me know the outcome. ![]()
Best AnswerThanks for the reply.
Clock face: I was able to change it via the computer app. I didn't realize that the cell phone app wouldn't have the same options & settings for the tracker.
Call Noitification: The trouble shooting tips you seem to be for problems with the phone/tracker communicating. My problem is that none of the apps (computer or cell phone) have call notification listed in the settings. I would like to turn call notification on but it's not an option in my apps.
@JonesM@techy101@WendyB@Joaris333 Thanks for bringing this to our attention! I'm currently working with our Product Specialist Team who is looking into this for the Android app as the setting is missing. When I get an update on this, I will make sure to share it with you all here first.
As a workaround, please edit your "Clock Display" setting from the online Dashboard's "Device Settings" page.
Thanks again for reporting this!
Moved this thread from the Charge HR to the Android section to increase the chance of getting a solution.
Wishing a wonderful weekend
Hi @PatriciaC89, I moved your post to the Android board.
Check out the lead post for more information on the issue you're experiencing!
